0 members (), 134 guests, and 4 robots.
Topics128,149
Posts1,056,818
Members48,456
#1196371 12/22/2016 2:48 AM
I read on line about a fellow that took a 250 3 belt damper and made it into a 2 belt for a 270. he turned the 3rd pulley off then turned the shaft down some and had a 2 pulley damper. anybody know anything about this?
Jay D.
I believe Hot Rod Lincoln has done this. He posts often so you should be able to PM him.
Evan
The 3-belt damper fits a 292. What is the diameter of the crank snout on the 270?
