| | | Forums66 Topics128,141 Posts1,056,779 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 223 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 223 | I read on line about a fellow that took a 250 3 belt damper and made it into a 2 belt for a 270. he turned the 3rd pulley off then turned the shaft down some and had a 2 pulley damper. anybody know anything about this?
Jay D. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I believe Hot Rod Lincoln has done this. He posts often so you should be able to PM him.
Evan
| | | | | Joined: Feb 2004 Posts: 29,844 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,844 | The 3-belt damper fits a 292. What is the diameter of the crank snout on the 270? Jerry
