2 members (Uncles51, Lostbuthaulinass), 79 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#1196374 12/22/2016 3:00 AM
Why am I suddenly seeing so many DTM (Direct to Metal) primer ads. Wasn't primer always DTM?
Allen
1974 Stingray Corvette
Allen Lane #1196409 12/22/2016 5:54 AM
Yes, but some are now better suited for DTM applications, hence the DTM marketing.
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Allen Lane #1196425 12/22/2016 1:12 PM
I used some high build many moons ago, I think by Dupont(?), that you could not spray directly over bare steel. You needed the etch primer first and then the high build.
Allen Lane #1196471 12/22/2016 9:45 PM
Generally speaking, many items can be called DTM but most that are called DTM are not as good as products that are called primer.
To clarify, if you are painting bare steel, epoxy primer then high build primer then paint is always going to be the best corrosion protection.
If you want to use a DTM high build, just know there is a better coating solution for anti corrosion properties.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
