3 members (Hotrod Lincoln, baldeagle, 1 invisible), 67 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,420
#119632 02/21/2006 10:58 PM
WHAT COLOR FOR ENGINE,TRANS,FAN,OIL CANISTER,REAR END,
I HAVE SEEN BLACK ENGINES,LIGHT GREEN ENGINES,
ORANGE, AND CHEVY RED. DID GMC USE ANOTHER COLOR BACK THEN,?AND HOW MANY COATS?
#119633 02/22/2006 12:00 AM
not sure about the engine color for GMC, but if it's CDN and has a 235, then it'd be gray - the trans and rear end weren't actually painted from all I've seen, but mostly folks paint'em black, as well as the fan and oil filter, tho that depends on the brand too - starter and generator black as well
#119634 02/22/2006 1:10 AM
I just used 'CAST IRON' color for the engine, head, bellhousing and pan. Put 4 coats on. The valve cover and two pushrod covers are a different color. The starter is silver body and the end is black.
Jim & Caroline
#119635 02/22/2006 2:05 AM
THANKS GUYS THAT HELPS ALOT.
GRAY IT IS FOR THE ENGINE AND BLACK FOR ACCESSORIES.
CAST IRON FOR THE TRANS AND REAR,SILVER FOR THE DRIVE SHAFT ,MY OIL CONTAINER IS YELLOW SO I WILL STAY WITH THAT.BLACK ON THE FRAME .SHOULD BE DONE THIS WEEK-END WILL POST PICS ON SUNDAY
#119636 02/22/2006 3:16 AM
Socket Breaker
Socket Breaker
plz stop with the all CAPS. It is considered to be the equivalent of 'shouting' online.
-W
#119637 02/22/2006 7:47 PM
sorry.........
i'm all thunbs with "the box"
thay didn't have the paint i needed at cannuck-tire so i went with chevy orange and black manifold paint for starter and fan etc,..hope to start on painting the frame this week-end
