3 members (tesa, 55shaker, Bill Hanlon), 58 guests, and 0 robots.
Topics128,076
Posts1,055,924
Members48,430
#119629 02/19/2006 5:49 PM
how do you remove the radiator core support bolts on a 65 chevy pickup? the old ones rusted to the body mount washers so i couldn't lift it off the frame so i had to cut and grind the smack with a hammer so i could get em off so i need to get the old ones out to put new ones in was gona take em out anyways to put in longer ones for the body lift that i'm going to be putting in
thanks
Nate
Link to my photobucket for pics of my vehicles
http://s238.photobucket.com/albums/ff17/OldIronChevy/
I think those have a "butterfly" lock washer bent up around them and you will need to take a pry bar and bend the locks back off the nuts so you can turn them out.
If you will look at ebay item number 8039092312 it will give you an idea of what I am talking about.
Hope this helps,Hobert
"The Lord is my shepherd"
if i'm understanding you right your talking bout how to unbolt them? i already got the front clip and stuff off now i just have to get the bad bolts off the core support not core support off the frame, i appologize if i misunderstood you
Nate
