| | | Forums66 Topics128,067 Posts1,055,877 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | how do you remove the radiator core support bolts on a 65 chevy pickup? the old ones rusted to the body mount washers so i couldn't lift it off the frame so i had to cut and grind the smack with a hammer so i could get em off so i need to get the old ones out to put new ones in was gona take em out anyways to put in longer ones for the body lift that i'm going to be putting in thanks Nate | | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | I think those have a "butterfly" lock washer bent up around them and you will need to take a pry bar and bend the locks back off the nuts so you can turn them out.
If you will look at ebay item number 8039092312 it will give you an idea of what I am talking about.
Hope this helps,Hobert
"The Lord is my shepherd"
| | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | if i'm understanding you right your talking bout how to unbolt them? i already got the front clip and stuff off now i just have to get the bad bolts off the core support not core support off the frame, i appologize if i misunderstood you Nate | | |
