6 members (Millenimech, Gib70, Hotrod Lincoln, Steelonsteel, Gray_Ghost, 1 invisible), 149 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
I recently acquired a '58 261 that I removed from a '58 C60 Viking. The engine was original to the truck and it has a factory PCV system on it. On the passenger's side of the block where the draft tube normally is, there is a stand pipe with no draft tube on it that has a npt fitting in it with 90 screwed into it and then a metal PCV valve screwed into that. From there it's hard-piped across the valve cover to a fitting on the intake below the carburetor. I have no doubts that its a factory setup, I've just never seen anything like it before on any engine this old. Is this a rare piece or was it common on 261's of this vintage?
1950 4100 - unrestored and driven weekly for almost no reason at all.
you'll find the setup in the shop manual, it was an accessory for all the I6 engines
Yup .......even back in 58' they realized sucking the condensation and combustion byproducts out of the crank case had real merit and huge benefits.
Yup ....... even back in '48 (for one model GM truck - model 3742).
Even the WW2 Chevy 235 in late 1942 used a PCV system.
Lots more pictures
I think 1948 was the first year as standard equipment on a Chevrolet truck?
In 1952 it became an option for some other Chevrolet truck engines.
Also fitted on WW2 Canadian trucks for the 216.......
Merry Xmas everyone.
Bob C.
CMP Heaven
The Hammond Barn
