| | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 61 Member | | Member Joined: Aug 2005 Posts: 61 | Soon I'll tackle the job of stripping the very dark green paint from my 36 truck's dashboard,,and attempting to give it a wrinkle finish. I have grey wrinkle spray..which will be followed by the light brown that was the orig look...any tips on this job? Any new "wrinkles" in application...will wait for a hoty day to do it...don't want any part of Heatlamps or hairdryers.
bruce duykers
| | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | Hey Bruce, I did the entire inside of my 60 cab by hand using sandpaper and scotch brite pads.
I didnt take my paint of to bare metal, I left as much of the original primer as possible and cleaned that up with tack cloth, several times using new cloth each time.
I applied one thin coat of the wrinkle paint as a base primer and wet sanded that with 400gr paper. I then applied two more coats of wrinkle sanding between these coats with 1000gr wet paper.
I am at that point now and trying to decide if I need a clear coat for protetion from keyring scratches etc.
I used two colors of gray to give me that original custom delux cab look.
I took my time and used lots of tack cloth to keep the dust cleaned up because I wanted to work in a dust free area.
Hobert
"The Lord is my shepherd"
