1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1195991 12/19/2016 3:15 PM
where can i get a dust cap for the front kingpin. Tks Mike
mcannon #1196006 12/19/2016 4:47 PM
3B Offline
Hy mcannon, what size of truck are you needing parts for? Do you want the cap for the top or bottom of the kingpin, or the cap that fits in the front hub and covers the front wheel bearings?
mcannon #1196032 12/19/2016 7:55 PM
The cap for the top of the kingpin.
mcannon #1196037 12/19/2016 8:05 PM
With the cap off the top of the kingpin I have about 1/16th to 1/8th play, Is this going to be allright after i get grease in it or not. Tks Mike
mcannon #1196040 12/19/2016 8:44 PM
If you mean side to side play then the answer is it is worn out. You should have no detectable play.
1951 1 Ton Completed
mcannon #1196042 12/19/2016 9:16 PM
As truckernix posted ("You should have no detectable play."), grease will not make up for that (or any) looseness.
tclederman #1196044 12/19/2016 9:21 PM
Thank You very much. I have got new ones that will be here in the morning, Now i will try to get the old ones out. Thank Everbody ver much,Mike
mcannon #1196045 12/19/2016 9:24 PM
Is the king pin loose in the axle?
mcannon #1196046 12/19/2016 9:29 PM
not at all, trying to get the lock bolt out.
mcannon #1196048 12/19/2016 9:44 PM
What is the procdure to replace the kingpin.
mcannon #1196049 12/19/2016 9:46 PM
Loosen the nut to the end of the lock bolt - tap the nut/end with a hammer.
tclederman #1196080 12/20/2016 1:52 AM
Thanks for all the help today, got everything out and ready for new parts tomorrow. Tks and have a good nite, MOONSHINE MIKE
mcannon #1196196 12/20/2016 10:46 PM
where can you get the front spring wedges.
mcannon #1196289 12/21/2016 1:47 PM
Crusing in the Passing Lane
NAPA, etc., make sure wedges are thinner than head of spring bolt.
Ed
