2 members (Southerntruck, Bill Hanlon), 52 guests, and 4 robots.
Topics128,080
Posts1,055,952
Members48,430
#1195927 12/19/2016 12:48 AM
I have 50 chevy and only parts for door windows I have are regulator and 1 channel on hinge side. What parts do I need? Channel for latch side? Channel for glass? Window glass with trim around glass or just glass? What about channel at bottom of glass to afix to regulator. I am very confused about my options. What do I need to put window in door?
old norse #1195929 12/19/2016 12:56 AM
old norse #1195948 12/19/2016 3:00 AM
!950 will need:
*The the channel at the latch end of the door (3 screws hold it on).
*Felt C-channel which surrounds the door glass.
*Window glass and the metal framing which surrounds the glass.
*The lower slide which bolts to the bottom of the glass frame (four screws) and accepts the rollers of the regulator.
*Inner door glass trim which has a fuzzy strip at the bottom to prevent the glass from rattling when partially open.
*A trailer load of patience.
*A 55 gallon cuss barrel.
Carl
old norse #1196068 12/20/2016 12:30 AM
Thanks much. I did not check shop manual but I will use that as resource. Carl thanks for laying it so a layman can visualize what is needed. "I have all the patience in the world but just don't have time to use it.'
