Brrrr
place holder
7 members (Shade Baby, Lightholder's Dad, DoubleB, Oswald, Sjm, Phak1, 1 invisible), 131 guests, and 2 robots.
Topics128,271
Posts1,058,417
Members48,485
I have a 1951 Chevy pickup and I am thinking of putting it on a 78 GMC frame. As this frame is 15 ½” longer I was wondering if anyone has extended the cab on their truck? If so what am I in for?
Red dot, center of chest ...
I saw an AD truck that had a second cab welded on to make it a "crew cab" like modern trucks. If you know how to weld, you can do almost anything.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
I was thinking that if I cut off the existing cab off just behind the door posts and if I can find a second cab and (after measuring) weld the doors shut cut the needed amount in front of the door posts then I would eliminate half of the welding and be able to keep the lines intact.
Fox Offline
If you've never done any sheet metal work before I wouldn't if I were you. I suspect you will very soon be in over your head and will become very frustrated. It takes a lot of skill to do this properly.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Making an extended cab and/or a double cab is done a lot in the custom circles. Always see 1 or 2 at the larger shows. It takes a pretty skilled metal worker to get it right.
If you really want use the GMC frame, it'd surely be easier to shorten the chassis by 15 1/2" rather than do the complex sheet metalwork involved in extending the '51 cab
You will have issues with the '78 drive train. The wheels will stick out of the fenders quite a bit.
Thanks for the information guys. I don't want to get in over my head. I would like to make this a 4X4 but will do what ever it takes to get her back on the road.
Have you done this before or know of someone who has tried this? Is it possible to get offset rims to compensate for the width problem?
Moving the wheels in may cause clearance problems on the inside of the tires/wheels. Jeffrey
I would recommend using a narrower frame and save yourself a lot of head aches. I personally hate seeing too wide of a suspension on any type of truck or car.
If you do want to extend your cab, here is a link to my build. I stretched mine 10 inches.
http://67-72chevytrucks.com/vboard/showthread.php?t=592642
I wish that I had your skills and a shop like that to work on it. But I will do my best with what I have and build the skills and tool inventory to make the next one better than this one.
I now live in Ruidoso, NM if you ever make it this way. Feel free to give me a holler if I can give a hand or advise.
Moderated
Moderated
It can be done. I have a '49 extended 23 inches sitting on a mid 80s chassis. 454 auto a/c great driver not a show truck. 402 677-6953 for pics. Clyde915
'49 Chevy 3100 Ext. Cab
'94 GMC C1500 Suburban
