2 members (Joe H, PAUL Berardi), 140 guests, and 2 robots.
Topics128,111
Posts1,056,246
Members48,437
#1194139 12/06/2016 9:08 PM
What is this CLIP used for?
There is one on each side of the dash (under) in the same location.
This is a 1946.
HAROLD
Harold
Hi Harold; I don't recall my truck having one. Two thoughts: The windshield drain tube and the vacuum line both pass by that spot? Could it be it is pulled out instead of pushed in? Too long ago since I did that.
GW,
It is not the drain tube or vacuum line. They both go behind this area. I have both installed already. I see no corresponding "match" on the dash itself.
They must have had a purpose for GM to place one on each side. Just curious!
Harold
Harold
Maybe the wire loom from the dash gauges?
I am working on two 46 right now and both have the clips on both side of the dash. I think they are use to hold the windlass in place. I could be wrong because I have not installed the windlass on either truck yet, but there is a lot of distant between the area where the windlass has inside molding that holds it down. Good luck Jerry
My first prewar and it will not be my last. Done with the 40 for my best friend. Got a 46 (year I was born) to build for me.
Jerry,
Thanks for your comment. I had come to the same conclusion. I placed the new windlass against the clip but have not figured out how to make the attachment. I hope to go see an old unrestored truck next week to see if I can see this area under the dash cover.
What stage are your 2 trucks in?
Harold
Harold
Harold,
I looked on my 1941 and 1942 military trucks, and both of them have the clips on both sides. It does not appear like the clip was ever used for anything on either truck.
Paul
Lots more pictures
Harold, one is 90% done and the other one is about 60%. my clips are a lot tighter to the door frame than yours. Good luck Jerry
I found the same clips on my '46. Neither appeared to have been bent or crimped to indicate securing anything. I wonder if they were simply an assist of some kind that was used on the factory assembly line. Maybe holding part of the wiring harness out of the way, before being fished through the firewall? Clips on right and left to accommodate right or left builds???
Hello all,
I think I have solved the mystery of the clips. I installed my dash today and it was obvious the clips were there to add rigidity to the midsection ends of the dash. The ends rested perfectly on the spring type clips and made everything line up when all the screws were tightened.
Gee, I love a good ending when the mystery is solved!!
Everyone have a very Merry Christmas.
Harold [b][/b]
Harold
