5 members (Otto Skorzeny, Barnfind49, Oldcaliforniakid, kades51, 1 invisible), 65 guests, and 1 robot.
Topics128,050
Posts1,055,671
#1194552 12/09/2016 9:47 PM
I have installed a 1958 235 engine in my 1953 1/2 ton. Will the header from the '53 (I no longer have it) match up to the '58 manifold? Thanks.
twheelock #1194563 12/10/2016 12:29 AM
What I do know is that the exhaust manifold from a 1958 235 fits a 1954 235. Someone that knows will post. Jeffrey
I believe there's a difference in the angle of the outlet flange. Later model manifolds angle the pipe back toward the firewall while early ones exit straight down. As far as the bolt-up to the head, either one should fit.
All 216 exhaust manuals went straight down, and 235 exhaust manuals went straight down through 1949.
All 1950 and later 235 (and all 261) exhaust manuals angled rearward.
1958 and 1954 235/261 exhaust manuals will interchange.
The 1953 exhaust manual might attach to the later heads - maybe someone else can confirm this (are the ports the same size?)?
twheelock #1194729 12/10/2016 10:03 PM
V
V Offline
My 49 216's exhaust manifold angles back towards the firewall.
It's the same angle as both the stock exhaust manifold and Fenton dual exhaust manifolds on my 54 235.
twheelock #1194731 12/10/2016 10:22 PM
Volfandt,
What is the casting code on the 216 stock manifold?
Someone might have switched to a later 235 manifold over the years?
As I recall, the front Fenton goes straight down and the rear Fenton angles rearward.
Also, one used the earlier donut gasket (forward?) and one used the later flat gasket (rearward?).
twheelock #1194751 12/11/2016 12:14 AM
V
V Offline
As far as I know the engine was stock and no major alterations were done to it. That said it's always possible. I knew the original owner but he passed away before I ever know about the truck.
I'll check the casting code and post it later.
Here's a pic of the Fenton headers on the 235. The front does appear to be straight down. The rear is supposed to line up directly with the existing pipe.
twheelock #1194753 12/11/2016 12:33 AM
Yep, the forward one in straight down and the rearward one slants a little to the rear.
Nice photo, Volfandt
