2 members (Hanks custodian, TooMany2count), 102 guests, and 0 robots.
Topics128,134
Posts1,056,403
Members48,441
#1194372 12/08/2016 4:27 PM
** Just now starting the disassembly process of my 100 percent orig. & untouched 1953 Suburban for an off frame restoration and noticed something somewhat strange {at least it seemed strange to me} when removing the orig. headliner & bows it looks to me like each piece of the headline was factory installed from the rear with the most forward piece being installed last. ** Just wondering if any of you Suburban guy's agree??
That is correct - install starting in/at the rear.
The rearward edge of last/forward piece of headliner is inserted into the last metal bow; then, the front edge of the last piece gets "tucked" under the upper edges of the windshield rubber-seal.
That's how we did my uncle's. With the kit we got the only piece that came precut was the front piece and it didn't fit very well. Seemed to be cut too short in some areas. Other than that it looks really good.
I didn't take mine up to the rubber. I let the inner windshield trim hold it in. On the sides, though, the windlace holds it in.
OOPS - BIG mistake on my part - I was referring to 54/55 regarding the windshield seal. The windshield/seal changed in 54.
