| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | What is the correct inline fuse size for a 6 V. Radio and a 6 V. Heater in a 1946 P.U.? Thanks. Harold
Harold Is a restoration ever finished? | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Could be wrong but I don't believe either of those devices had a fuse in 1946. So if I am correct, there is no right answer. So, what is one to do? Do you have an amp meter? You could put it in line with the devices temporarily to measure the current and go from there. On the heater an ohmeter would work, but the radio will require the amp meter. On the other hand, a fuse is used to protect the wire downstream from it. So if you know the gauge of the wires going to the devices you could use that as a guide.
| | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I don't know about the radio but my 54 3100 has a 20 amp fuse on the heater. The Heater was still the old 6v setup when I bought it. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would suggest a 15 amp fuse for each. The radios always had fuses. They used to have a fuse holder for the radio that threaded directly on the Gen side of the ammeter. Inline fuses should work just fine. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Tim & Fred, Thanks for your response. Instead of inline fuse I should have said fuse holder. It uses the Buss Glass fuses. Tim, This RADIO was used in the trucks. Thanks again for your replies. Harold
