7 members (TUTS 59, WICruiser, 1955 1 Series, Gray_Ghost, Phak1, 3B, Otto Skorzeny), 123 guests, and 1 robot.
Topics128,105
Posts1,056,552
Members48,448
Hello Stovebolters,
I have a 1940 Chevrolet truck that I am restoring. I have yet to have the engine running so I do not know if the pedal start works.
My first thoughts are that it would mean fitting a different:
* starter motor;
* a fly wheel that has a ring gear fitted;
* a new ignition switch - or button with a new wiring circuit.
What else would be involved in the conversion?
My truck is a 1940 3 ton tray back (Australia) stake side or flat bed (US?)
What year, model, and parts numbers would I be after to make the conversion?
Is it also worth the effort and expense to do so?
Kind Regards
Lionel
3B Online: Content
3 Online: Content
Hy Lionelgee, you are correct you will need a solenoid type starter from an early fifties automatic equipped car (six volt). The existing flywheel will work with the new starter providing the ring gear is in good condition. You can keep your ignition switch and add a push button to activate the solenoid. The stomp starter system will probably work they lasted for years, good luck whichever way you decide to go.
I like the foot start. Any way before replacing see if it works first. Not broken then don't fix it. Jeffrey
Stomp starters are generally reliable. Seems like a lot of work to make it a key start. Early '50s car starters weren't energized by the ignition switch. They used a heavy duty momentary push button switch.
just keep the pedal, it is almost an anti theft device. It works, and it isn't really worth the trouble.
G'day Everyone,
Thank you for the replies, they are very much appreciated.
Happy restorations everyone, a restorative festive season and an enjoyably productive 2017.
Kind Regards
Lionel
