7 members (Peggy M, mick53, Steelonsteel, Otto Skorzeny, Robert Crandall, Charles in CA, JW51),
130
Mod | | | Forums66 Topics128,109 Posts1,056,267 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | What is this CLIP used for? There is one on each side of the dash (under) in the same location. This is a 1946. Thanks, HAROLD
Harold Is a restoration ever finished? | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Hi Harold; I don't recall my truck having one. Two thoughts: The windshield drain tube and the vacuum line both pass by that spot? Could it be it is pulled out instead of pushed in? Too long ago since I did that. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | GW, It is not the drain tube or vacuum line. They both go behind this area. I have both installed already. I see no corresponding "match" on the dash itself. They must have had a purpose for GM to place one on each side. Just curious! Harold
Harold Is a restoration ever finished? | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Maybe the wire loom from the dash gauges? | | | | | Joined: Jan 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 45 | I am working on two 46 right now and both have the clips on both side of the dash. I think they are use to hold the windlass in place. I could be wrong because I have not installed the windlass on either truck yet, but there is a lot of distant between the area where the windlass has inside molding that holds it down. Good luck Jerry
My first prewar and it will not be my last. Done with the 40 for my best friend. Got a 46 (year I was born) to build for me.
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Jerry, Thanks for your comment. I had come to the same conclusion. I placed the new windlass against the clip but have not figured out how to make the attachment. I hope to go see an old unrestored truck next week to see if I can see this area under the dash cover. What stage are your 2 trucks in? Harold
Harold Is a restoration ever finished? | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Harold,
I looked on my 1941 and 1942 military trucks, and both of them have the clips on both sides. It does not appear like the clip was ever used for anything on either truck.
Paul | | | | | Joined: Jan 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 45 | Harold, one is 90% done and the other one is about 60%. my clips are a lot tighter to the door frame than yours. Good luck Jerry
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | I found the same clips on my '46. Neither appeared to have been bent or crimped to indicate securing anything. I wonder if they were simply an assist of some kind that was used on the factory assembly line. Maybe holding part of the wiring harness out of the way, before being fished through the firewall? Clips on right and left to accommodate right or left builds??? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Hello all, I think I have solved the mystery of the clips. I installed my dash today and it was obvious the clips were there to add rigidity to the midsection ends of the dash. The ends rested perfectly on the spring type clips and made everything line up when all the screws were tightened. Gee, I love a good ending when the mystery is solved!! Everyone have a very Merry Christmas. Harold [b][/b]
