Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Peggy M, tclederman, 2 invisible), 53 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#1194019 12/06/2016 1:20 AM
Anyone know what diff ratio a 1952 Car diff is?
I found some one selling the whole 1952 rear end including torque tube in my area and I was wondering if I could swap it into my 37 Chev 1/2 ton Pickup to get better top speed
Den99 #1194025 12/06/2016 1:38 AM
Den99 #1194044 12/06/2016 3:48 AM
nice truck
Redryder pix
My Hotrod
Den99 #1194112 12/06/2016 6:06 PM
Not sure it would mate up to your transmission or if it is the same wheel base but a 52 car would have a 5 lug bolt pattern.
Fred
Den99 #1194119 12/06/2016 6:42 PM
Y
yar Offline
Y Offline
Den,
I've been through that exercise:
http://vcca.org/forum/ubbthreads.php/topics/334876/1936_Chevy_3.55_rear_gear_conv
Your '36 PU has spiral bevel gears and the '50-'54 Car rear ends are hypoid so swapping in the gears is not an option.
Swapping in the whole rear end probably won't work either because of differences in track, spring mounting method, driveshaft length, driveshaft splines not matching your U-joint and 5 vs. 6 lugs.
You might consider a '37 car rear end and swapping in the gears you want. That will eliminate some of the problems.
Ray
Den99 #1194146 12/06/2016 9:54 PM
Thanks for your answers
