| | | Forums66 Topics128,066 Posts1,055,874 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 39 'Bolter | | 'Bolter Joined: May 2015 Posts: 39 | Does anyone have any info on 51-54 Chevy truck Seat Adjuster Return Springs, GM 3698449? Mine are missing from my 54 stock bench seat. Parts book seems to call for two. One on each end. Any photos or info on an available reproduction would be great. Thanks | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I think you're best bet would be to go to a junk yard and and get the parts you need from there.
Pete | | | | | Joined: May 2015 Posts: 39 'Bolter | | 'Bolter Joined: May 2015 Posts: 39 | Thanks Pete. I just found one at a junk yard for $5. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That is not junk (it was not discarded AND useless) - you really needed it - you should hold that parts yard in higher regard. Good job on finding it, and, good advice, Pete | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | If you have one take it to hardware store and match it. The good news is you have one to compare.
Ed
