5 members (Jon G, Hotrod Lincoln, Otto Skorzeny, BC59, 46truck), 109 guests, and 3 robots.
Topics128,122
Posts1,056,331
Members48,439
I want to put a dodge Cummins & newer running gear in an AD Chevy. I want it to pull a stock trailer with a 15 to 20k load. should I get a 49 Chevy one ton to start with or go with a 1 1/2 to 2 ton truck? I want to show the boys at the sale barn with the $50K pickups what class is !!!!
I just finished a 1946 chevy pickup street rod
now on a 1950 chevy 3100
also a GMC 220 with duals
and a 1948 chevy 2 ton
The 6BT is not an easy fit in an AD truck though some do it. None I've seen looked like much fun or were very kind to the original truck sheet metal.
•1952 Chevrolet 3800 pickup
---All pictures---
Much easier than stuffing a Cummins into an Art Deco nose like mine but still a very tight fit. Don't know about the AD's but as I recall, the war year trucks pretty much all had the same dimensions as far as the frames. I'm guessing you are looking at a 6BT, mine is a 4BT with the only difference being two more cylinders, so same width, just longer. I had to set my 4BT back almost two feet to get it into the frame because it gets narrower towards the front.
The Cummins swap is tricky, but I believe worth the effort as you can pull a house and still get surprisingly good mpg.
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
Crusing in the Passing Lane
If you are keen on an AD truck, a 4BT will be a decent job as stated above. 6BT will definitely be a challenge. GMC trucks have slightly more room in the engine compartment since the engine is 3" longer, but fitting a suitable radiator and I'cooler will be a challenge.
Late model running gear with disc brakes should be used. Best use one ton running gear. Might want power steering(doable but a challenge) and brakes(doable.). If open to other options, larger than one ton GM trucks, 520, etc., for AD style, and T-18 for late '30's body style all have plenty of room for a 6BT, although with a slight weight penalty.
I have a '37 T-18 that has room for a 6BT, I'cooler, hydroboost brakes, power steering, full width modern front and rear axles.
Ed
fount this the other day.in the exact samething but I just picked up a 92 dodge d350 to do this with
Congratulations on picking whole truck with modern running gear, much easier, safer.
Ed
When you get ready to do this you might as well plan on changing the rear axle as well. Otherwise you'll just be wasting the power that cummins will make. These trucks were geared extremely low to make use of the low power outputs of the 235. I have a '50 4100 (1.5 ton) and it has a 6.17 gear. The 2 ton trucks could have an even lower gear. About 40mph will be the top speed - especially with a governed diesel.
1950 4100 - unrestored and driven weekly for almost no reason at all.
H Online: Content
Put an early 1950's big bolt cab and front end on a Mopar/Cummins dually frame and running gear. You'll have all the advantages of a modern chassis and suspension, and the appearance of an older truck. The wide fenders and grill up front should clear the wider front suspension and track width better than the narrow one on a 1/2-1 ton truck.
400 series and larger GMC might cover that front axle OK, anything smaller in an AD truck is still quite narrow, use your tape measure.
---All pictures---
There are wide fenders available for '41-'47 trucks, I have two sets if you want a px, send email.
Search around, some trucks came with thicker radiators, fuel haulers for one.
Ed
The engine compartment is the same on 1/2 ton up to 2 ton. The fenders are wider to accommodate 20" tires. A 55 and later has a mush larger engine compartment. I think you need to think the whole thing through before you ever start. A 55 or later is built for a V8. And a newer gas V8 would almost be a bolt in.
