2 members (Wayne67vert, moparguy), 134 guests, and 0 robots.
Topics128,101
Posts1,056,182
Members48,436
#1193594 12/03/2016 6:51 AM
I am trying to get optimum rpm at cruise. I have a 46 chevy on an s10 frame with approx 300 hp 350 with 400 trans and 3.42 rear. I am trying to get the right diameter tires. I will be using 15 inch wheels. I have used the ratio calculator and I don't know what rpm I should be shooting for at 55 mph. Examples, 25.5 dia tire. 2478 @ 55
26.1 dia tire. 2422 @ 55
28. Dia tire. 2257 @ 55
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
homer52 #1193614 12/03/2016 2:40 PM
I have a 2001 suburban 325 4spd OD on 16" wheels, 3.42 and if I remember correct, it's 55 mph at 1,500 rpm. And, when driving my usual 70 to 75 get 20.7 mpg highway.
I am taking a ride upstate tomorrow with the family for a Christmas tree and will record the rpm at various mph. I will also measure the tire's diameter.
So if you are wanting good mpg I would go with a wheel tire combination that would give a 30 - 31 tire diameter. Jeffrey
homer52 #1193620 12/03/2016 3:44 PM
Figure out where your torque is, and aim for it. My 250 inline with 100 hp likes to run at 2350 to 2450 rpm. I would suspect yours to be in the 1600 to 1800 range.
homer52 #1193621 12/03/2016 3:52 PM
25.5" diameter tire seems a little short. I have some cheap Cooper Trendsetters on mine, 235/75/15s on the back, and according to Cooper's website, the diameter is 28.66". You might try something closer to that diameter and see if it gets you closer to where you want to be.
homer52 #1193647 12/03/2016 7:04 PM
Do you have the specification card on the cam that's in your engine? The most economical cruise RPM will be just slightly above the torque peak. If you get it lugged down too far, the power valve in the carb will open up and kill your gas mileage, plus the acceleration will suck until you struggle up to the RPM where the engine starts making usable torque. Try running a vacuum gauge and see which size tire allows you to accelerate in top gear with the least amount of vacuum drop.
homer52 #1193648 12/03/2016 7:11 PM
At this point I have no solid info on the cam except it is supposed to be an RV cam, go figure. I guess I will just have to try a pair of tires and see what happens.
1941 Chevy
homer52 #1193670 12/03/2016 10:30 PM
That statement right there may well be the most logical and practical one ever written.
With a custom set up like yours, you have too many unknown variables to deal with to try to figure it out on paper.
Examples:
Stall speed of the torque converter.
Gear ratios of each transmission gears.
Camshaft profile.
I believe you figured out the best plan.
Carl
homer52 #1193821 12/04/2016 8:46 PM
I'd be inclined to go with whatever looks the best. With a light vehicle and a 350 close is probably good enough. John
homer52 #1195118 12/13/2016 4:30 AM
Try this website: wallaceracing.com/Calculators
Automotive calculators of all kinds including tire size/gears/trans/ to rpm
1940 Chevy KC 1/2-Ton
homer52 #1195119 12/13/2016 4:37 AM
