1 members (Hotrod Lincoln),
125
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 14 New Guy | | New Guy Joined: Apr 2016 Posts: 14 | Greetings! I am tearing down the 261 that was in my 48 2T truck (it was a replacement from the original 235) it was swapped out sometime in the 50's. The paint that is flaking off still is yellow and I want to repaint it the original color, so I was wondering if anybody knows what the color name/number to match it today, as well as what "brand" to use for the high-heat area of the engine.
Also, I was wondering if the oil pressure gauge in the dash (0-60psi) is correct for that engine.
Thanks for the info. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | An oil pressure gauge that reads 0-60 will work fine with a 261 engine.
No one knows an original paint code for the yellow or green paint used on various years of 261 engines.
Maybe someone will post a yellow code that they have used, and post a link to a photo of their painted 261 engine. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Not all 261's were painted yellow, correct? I read that they only did that for 2 years (53-54, I think??)
I need to paint my 58-62 261 block and was wondering what color (Green?) would be correct or close..
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** The green paint I used (got the information from another stovebolter} some time ago on my 261 is * Dupli-Color Engine Enamel called DE1618 Detroit Diesel Alpine Green purchased at O'Reilly's. Looks really nice.**
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 |
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | I'm working on a 1957 261 that was originally yellow, consistent with Tim's post. If your engine was originally yellow, the date code should place it as a 1957 as that was a one year only color, but Chevy wasn't always precise about engine colors and would use what they had until it ran out from what I have read. When I did some research about what shade of yellow to use, I found some posts elsewhere that stated that Old Caterpillar Yellow was a very close match. I also discovered that Old Caterpillar Yellow has been discontinued by most paint manufacturers and replaced with New Caterpillar Yellow, which supposedly a different shade. I was able to find some Krylon Farm and Implement Old Caterpillar Yellow with a Google search, but it was very expensive and I was concerned that I'd never be able to find it again in the future if I needed touch-ups or had to paint a replacement part. I ended up using Rustoleum Farm Equipment John Deere Yellow. It seems to be a close match to the yellow that I was able to uncover on the engine under several layers of Chevy orange paint. I like the look and can post pix if you want. I found the best price at Home Depot if ordered online with free shipping delivered to the store for me to pick up, $22.56 for a case of six cans. http://www.homedepot.com/p/Rust-Ole...-Spray-Paint-Case-of-6-7443830/202058760I am colorblind, so I can't be a great judge of paint shades. My wife helped me. Matt | | | | | Joined: Apr 2016 Posts: 14 New Guy | | New Guy Joined: Apr 2016 Posts: 14 | Thanks guys, That is what I will do, find a yellow that is close. I am a John Deere fan so the JD Yellow sounds good/looks good/works for me.
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Got any photos of the original yellow?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Chris, Links to photos have been posted in the past (I'll look for them). As I recall, there were different shades, which would be expected due to aging, different hues at different times/plants, and color-rendering error due to different cameras, scanners, digital-storage, and digital display. I have seen two supposedly original "yellow" painted 261s (one still owned by Bob Adler, and one on a truck at a show). Shades of gray/green for 235/261 engine pants (especially 1954 and later) offer as much or more confusion and variability (as you know). I'll edit/ad links to photos of yellow 261: - old thread - Cosmo posted links to photos, but the links no longer work - cannot find other older links/photos - dead links - results from a Google search | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | These are the best pictures that I could find. I know that I took some others that showed lots more of the yellow after I stripped off more of the orange paint with a turbo nozzle on my pressure washer, but I can't find them. I'll post if I can find them. The reason you won't see any yellow on the block itself is because the engine came out of a '57 cement mixer with a replacement '64 block. Everything on the engine except the block had the yellow paint. http://s844.photobucket.com/user/ma...1318_zpsiifxozvj.jpg.html?sort=3&o=0Matt | | |
