| | | Forums66 Topics128,192 Posts1,057,351 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I have a 1958 chevy Viking 60. There is a 1957 GMC 370 near me that has the 6 lug wheels and tires. From what I can gather, the GMC 370 is a 2 1/2 ton. My questions is, are the brake drums interchangeable? I know I could swap the whole rear, just wondering about the parts though (mainly getting an extra set of brake drums, not to mention tranny!) | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy 69Cuda, could you be more specific on the parts you need to know will interchange? Going back and forth between GMC and Chevy parts books is driving me crazy (a short trip to be sure). There are many choices of rear brakes depending on the GVW of the truck or rear axle. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | mainly, I am interested in the brake drums. I think the rear may be different since the GMC is electric shift and Chevy is vacuum shift. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | The vacuum shift rear is more than likely the GM Corporate rear. The electric shift rear is more then likely an Eaton rear. To the best of my knowledge the drums are different... Mike B  | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy 69Cuda, I don't think the rear brake drums will interchange, but without disassembly and measurements I can't be sure. The Gmc parts book is huge but unfortunately they do not reference the brake drums to a given series they list them on a chart by dimensions. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | If they both have 6 hole Budds, they should both have a 37544315 14"front and a 3754316 15" rear. I doubt that the part number will be cast on them. If there is a number, it will probably be a casting number. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Thanks guys, both trucks have 6 hole budd wheels. I am going to go look at the GMC tomorrow. I may pick the whole thing up and part it out. I have no use for the engine (although it is seized) and a lot of the cab parts have been stripped already. At least I would have an extra set of 22.5 wheels to sell and probably some other stuff.... and then haul the leftovers to scrap to almost pay for my gas going and getting it! LOL. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | well, I passed on the GMC, super rusted, cab is stripped, doors gone, widow maker rims, not sure what tranny it has, not an SM420 though. (PTO on both sides) manifold gone off engine, this is in sad shape unless you need parts! | | |
