9 members (Nick in Manitou, Gray_Ghost, Shade Baby, J Lucas, TUTS 59, Bill Hanlon, papas52, 2 invisible),
120
Mod | | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 65 Member | | Member Joined: Jan 2003 Posts: 65 | Hey guys - I'm in the middle of color sanding the 'burb and will soon move to the compounding stage. I'm using 1500 paper with an dense sponge block and a real light touch just enough to take out the dust and other high stuff not going to sweat the orange peel for a super mirror finish. What I found is, it takes a hell of alot of elbow grease to make the 3M Perfect- It cut the scratches. I'm very reluctant to move to a buffer as with all those curves, welting and mouldings, I'm sure to zip it down to primer or worse. Any suggestions for an more aggressive compound or buffing style? | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Hello partnter 3m makes another coarse cut ,part#05936 works way faster than the regular.dont be scared of the buffer,just keep it farly flat and moving good luck! | | | | | Joined: Nov 2004 Posts: 61 Member | | Member Joined: Nov 2004 Posts: 61 | Sanderson, if your not well versed in wetsand and buffing, go to 2000 wetsand after 1500 it will help a lot, you may have let it cure more then you should have before buffing it! | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Another dumb question. What is color sanding and why? Weeds | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Sanderson, you DO need to be careful on the interior (concave) curves. I gouged through a bit but my paint was by no means pristine so I didn't worry about it. | | | | | Joined: Oct 2005 Posts: 41 New Guy | | New Guy Joined: Oct 2005 Posts: 41 | I would highly reccomend using foam pads on your buffer as opposed to the sheepskin style, they are much more forgiving on corners, curves and such and seem to do a much cleaner job. I like the Meguiars dual action cleaner/polish, not super aggressive but pulls out the shine quickly. As bodiman suggested make sure your paint is cured well.
You never have enough, til you have too many!
| | | | | Joined: Oct 2005 Posts: 35 Junior Member | | Junior Member Joined: Oct 2005 Posts: 35 | As Bent stated the 05936 is the stuff to use initially but don't forget to follow up with one of the Perfect-It glazes when you're done compounding. The glaze you use will depend on the color of your paint, no kidding. If you're tired of color sanding here's another time saver. 3M makes a system called Hookit that allows you to use ultra fine sanding discs on your da sander. They even make a Trizact Hookit that is 3000 grit, that's right 3000! Amazingly enough the 3000 does actually cut although you can't feel the grit. ANyway, the point is that with this system you will be able to color sand to a finer grit faster than you're able to hand sand to 1500. The finer grit you use the faster the buffing will be.
Joe | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | foam pad and the proper compound is what you want to use | | |
