| | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 2 Moderated | | Moderated Joined: Nov 2016 Posts: 2 | I'm curious about putting a 1.5 ton chevy front end and cab on my 3/4 ton duramax everything else. I'm sure someone has done it I'm just not finding any info. I have both trucks, just want the drivability of my 02 under the old cab. Not about to show it, would probably still haul cattle with it, just don't know what I'm getting into. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | welcome to the site. I have not looked into this so, I am not much help! I believe the modern trucks have a wider frame than the older ones so, you will have to contend with that, steering column will probably need to be moved as it may be too far off-center for the older cab. | | | | | Joined: Apr 2015 Posts: 113 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 113 | welcome. i have not done what you are planning but i did see an example of a combination 59 Apache front clip with a modern extended cab. looks like the bed is from the apache as well. if you go to the address i pasted below it should come up just scroll down a bit and you will see a light blue/teal truck. not the same as your 1950 but it may give you some inspiration.
https://www.google.com/search?q=59+chevy+truck&biw=1368&bih=764&source=lnms&tbm=isch&sa=X&ved=0ahUKEwitqebPxc_QAhUnqFQKHUDTDxkQ_AUIBigB#imgrc=LPZJQHVaPeAsDM%3A
1959 Chevy 8500 - Spartan 80 366 BBC
| | | | | Joined: Nov 2016 Posts: 2 Moderated | | Moderated Joined: Nov 2016 Posts: 2 | | | |
