4 members (Bill Hanlon, dt235sd, Gray_Ghost, blanch53), 367 guests, and 4 robots.
Topics128,087
Posts1,056,115
Members48,435
Bumped into USC All-Metal and did some reading. Aluminum based and you can powder-coat over it. Not chrome though.
Used it to do some grill work on my '54. A few observations:
* The only negative is that the reactor is pretty atomic. they say put 12-14 drops into a golf ball size of the filler. Too much. It only gives you working time under 5 minutes. I went to 8-9 and it was better but you still need to work pretty quickly.
* Did a coat...sanded it...then did another coat to build it up. These were on dents NOT holes.
* Hardens in about 20-30 minutes to a point where you can sand it. I used a circular grinder with 80 grit at #4 (of 6) speeds and it cut thru the All-Metal and feathered it very nicely.
* I am thinking if I was to fill a fender hole, I would start on the bottom of the hole with fiberglas cloth and filler (like DuraGlass) to create a backing. then I would use All-Metal to fill the hole itself.
Anyway, good product that is a bit pricey but satisfied so far.
Easier than that, you can put masking tape on one side, use the all metal, and peel the tape off afterwards.
I like easy. Thanks. Have you used it to fill seams?
I like the other kind of all-metal to fill holes.
before
after
grin
What he klhansen said! 100%! Seriously take a look at the work he does by clicking the photo links. Someone who really does nice work! Well done!
Great product but it is still a polyester filler. It and fibreglass filler should never ever never ever be used to fill a hole in steel unless you want to do it again after you paint it.
The only thing we can do to repair a hole in steel is to use steel by welding in a patch.
before
after
grin
Any other attempt to "fill" a hole will fail 100% of the time.
Fibreglass filler works great on boats, hot tubs or corvettes only.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
