4 members (Oswald, treegrower, Nick in Manitou, 1 invisible), 40 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
#1192934 11/29/2016 4:25 AM
The doors line up nice on my 53 gmc 1/2 ton but have a little play when closed and back of door sticks out, front is flush with fender,hinges seem ok. Any idea
new latches and strikers will fix that
Or .......that is about how good they fit when the truck was new. Making it fit better can be a challenge but doable with patience and the use of several tricks some involve brut force. There have been several how to articles on cutting the body or door or both to get a better fit.
Many an expert in body repair has spent 100's of hours ( $1000's) getting these doors to fiit and close like a modern car. The latch is just one small part, bear claw latch upgrade helps but the door frame and body opening MUST be correct ( perfect) to get a "NICE" fit all the way around.
Those stock latches have one other weak point........they don't stay latched. That's why the design changed to bear claw in later years.
New NOS latches and strikers are the way to go. Originals are 65 years old, good used are ???? old, repros are junk. I bought NOS for my '50 and it made all the difference. The reproduction door jamb latches were a full 1/4" difference from the NOS I used. Readily available on eBay and well worth the additional money.
https://www.flickr.com/photos/advance-design_parts_co/23486333483/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/16577213489/in/album-72157631868452754/
I suggest that you remove the striker and see if it closes all the way.
1951 1 Ton Completed
Insomniac
Insomniac
One of the doors on our truck didn't close all the way. With the door open, I could turn the latch with my fingers and it clicked twice into the closed position. When closing the door, the latch would only click once. Lubricating the latch solved the problem.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Way back when the family 54 Chevy Station Wagon was newish, my mom got t-boned by a drunk (nobody was hurt). Anyway, when my dad picked up the car from the body shop, the right rear door didn't fit quite right and he pointed it out to the guy, who proceeded to stick a wrench in the hinge side and slammed the door shut. Fit perfectly after that. Cost wasn't $1000's, and took no time at all.
Sometimes the brute force method is what it takes. grin
