4 members (Bill Hanlon, KEVINSKI, Gdads51, Otto Skorzeny), 130 guests, and 3 robots.
Topics128,164
Posts1,056,982
Members48,458
I know my question concerns something way newer than what the site is about, but I figured maybe you guys might he able to help...
I will be needing to repaint my '89 Chevy 2500 Scottsdale, which was originally built as a Cab & Chassis, and fitted with a Reading utility body.
It was painted red.
The paint code (?) from the sticker inside the glovebox is one of the following:
WA-L 8832 U 8832
7810
Does anyone know if any of these number correspond to a GM paint color, and if so ,which color ?
I've ditched the utility body and replaced it with a '98 fleetside pick-up box, which is a lighter shade of red...I need to paint everything to match once the warm weather returns.
The "original" paint on the cab (door jambs and all) appears to be a regualr red enamel, not a metallic or BC/CC...
Any ideas ?
Thanks...
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
Frank, w/ something that new you should be able to go to yer local bodyshop paint supply and look in their color chip books and find exactly what the code means - the codes on the truck will be GM numbers, but will be listed against various paint brand numbers - even my NAPA has a whole slew of books that cover all makes, car and truck, back to the 70's
Frank,
Maybe I don't understand the question. If you are going to paint everything, meaning the new bed too, why not pick a color you like instead of a color Detroit liked.
You are not going to be "matching" anything on a total repaint so wouldn't a paint number be a moot point.
Stuart
maybe he doesn't want to paint the jambs or under the hood and such, then he would need to match that. just look up '89 GM pick-up colors in a chip book, it'll be there.
Keith
If it were easy they'd have grade schoolers doing it!
X
X Offline
GM called the WA8832 color---(insert drumroll here)---Red. Very imaginative. It was used on '87-'91 Chevy and GMC full-size pickups, and should have been a BC/CC.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
Thanks Curt...
I didn't know if this was a commercial color, or what...
If I can get away with just painting the box to match the rest of the truck, that's as far as I'll go...
It's a work truck, not a resto project...I need to get it (mostly) the same color for my own peace of mind, and to keep the wife off my back...
Might be one of those "in for a penny, in for pound" deals too...If I have to buy the paint by the gallon, then I might as well scratch the whole thing and paint it all...
Thanks for your help, guys !
Frank McMullen
That WA8832 IS the GM color code and available at any paint store.
Another bit of info, the "L" and "U" that appear before the 8832 means "Lower" and "Upper" when refering to a two tone.
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
