3 members (TUTS 59, Jon G, Joe H), 97 guests, and 3 robots.
Topics128,026
Posts1,055,402
Members48,422
#119252 01/22/2006 3:42 AM
has any one in here used chassis saver does it work as good as thay say it does ???????
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
#119253 01/22/2006 6:41 AM
Ive used Zero Rust and ChassisKote and while both were good, so far I like ChassisKote better, but you have to thin it with toulene. But then again most paint is nasty stuff anyhoo.
#119254 01/28/2006 7:02 AM
Junior Member
Junior Member
When I did the frame off on my 57 T-bird I had the frame sandblasted and then brushed on POR 15 out of a quart can. The product is a little pricy but it cures nearly rock hard and the frame won't rust under the paint. The paint is UV sensitive so you couldn't use it where the sun will beat down on it. A frame should not be a problem. I'm going to use POR 15 on the inside of my 40 Chevrolet truck cab where it will never show, (floor boards, fuel tank box, inside doors etc.).
John M. (Marc) Knight
VTCI #33786
Thunderbirds, 64s, 57, 2002
40 Chev Truck (Rat) project for my 16 year old daughter
Bountiful, UT
