3 members (Otto Skorzeny, dt235sd, 2-Ton), 58 guests, and 2 robots.
Topics128,049
Posts1,055,661
#1190217 11/08/2016 10:55 PM
1959 Fleetside.
Anybody know of a vendor for the clips that hold the U-shaped trim piece that goes around the door windows on the inside. That piece mounts with a screw at either end, but the rest is held in place with spring steel clips, and mine were rusted out. I'm not seeing them on any of the sties I normally use.
thanks
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
Good luck......mine looked spot welded on. One was bent and I fixed it...but couldn't locate any.
MilkMater
1959 Chevrolet 3/4 Ton 3E
MilkMater
