| | | Forums66 Topics128,087 Posts1,056,119 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 25 | Does a 1945 1 1/2 ton have the same bolt pattern for the front wheels as a 1947 1 1/2 ton. I am wondering if the wheel retainer rings from a 1947 would work on a 1945. I don't have the rings yet but know where some are for sale. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Measure/compare bolt circle diameter and wheel center bore.
I'm not real familiar with the older trucks but I suspect bolt circle is 7.25" (5/10 lug hub centered). Center bore may or may not match, GM used 4.75" up to 55 but much earlier trucks were smaller, not sure what year they increased to 4.75", 30's or 40's perhaps. Later than 55 is 5.25" center bore. | | |
