| | | Forums66 Topics128,167 Posts1,057,096 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 14 New Guy | | New Guy Joined: Apr 2016 Posts: 14 | Hi all, I have been searching through the forums and haven't had my question answered. So, working through the brakes and suspension this winter. I started on the front passenger end and noticed a little wiggle when I try to shake the drum. The tie rod ends are not loose, pulled the drum off, everything seems okay there (will replace bearings anyway). Pulled brakes and wheel cylinder off and will rebuild those. The little wiggle is still there. It seems that the wiggle is when I push/pull the top or bottom of the brake plate. So, I believe that is a bushing around the kingpin (still digging out the dirt/grease). From what I have read that is not a good thing to have and a new kingpin/bushings are needed. However, since I have a big bolt I have the special bushings that if replaced they get reamed out to the proper size. Then as I continue to search through the forums it seems these tools are next to impossible to find. So finally my question: where/how do I rebuild this thing to fix the little wiggle?
Thanks, | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Not a difficult job. You can do the disassembly and fit new bushings in the spindle. Then can have bushings honed at most any automotive machine shop. Alternatively they can use an adjustable reamer with a pilot, you can find one and do it yourself, or a traditional machine shop may have this type reamer with pilot.
The goal is to have each bushing reamed exactly to size to fit kingpin snugly and also so they share centerline. The piloted reamer or long hone helps achieve the same centerline.
Grigg | | |
