Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Tyler Watts, Otto Skorzeny, BC59), 160 guests, and 3 robots.
Topics128,281
Posts1,058,464
Members48,490
Anyone ever use the AC Delco Rapidfire #7 spark plugs in a 216 cu.in. engine? Too hot, too cold? Results?
Tim
1970 VW Beetle
Any thoughts on these spark plugs?
1970 VW Beetle
They are just a standard replacement spark plug. They will work just like most any other plug. Set the correct gap and purchase the correct heat range and you will be good to go.
