1 members (Cletus1950), 65 guests, and 2 robots.
Topics128,151
Posts1,057,000
Members48,460
#1191585 11/19/2016 8:58 PM
Hi all,
I have a 1952 Chevy 3100 truck that has a persistent odor of gas in the cab. The gas tank was replaced by the previous owner. I’ve noticed what looks like residue from dried gasoline on top of the gas tank, along the entire length of the seam. Is this a common issue with replacement fuel tanks? Any clever suggestions, other than replacing the tank, to remedy this?
I noticed that the tie straps that secure the tank to the cab floor caused the gas tank seam to bend. Maybe this is the cause of the leak?
Thanks in advance for any suggestions on how to proceed. I’d like to avoid buying a new gas tank, but it would beat smelling like gasoline every time I drive around the block.
Thanks!
Billy
Have you checked that the filler neck and vent tube hoses are in good condition and the clamps are tight?
Also check that the sending unit gasket is not leaking.
Don't worry about the bent seams, they're pre-bent to form a saddle for the straps.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
If you find that it's not the sending unit gasket or the filler, there are cleaner/sealer kits available for gas tanks. I've seen them on Eastwood's site. My tank will eventually get that treatment, even though I don't believe it's leaking.
Thanks for all the replies. All of the hoses are in good condition and the clamps tight, so I think this may be a shoddy seam weld? Skooker - thanks for the info about pre-bent seams. I thought this might have been the problem until I read your note. I'll look into a sealer kit.
Did you replace the sending unit gasket? The new style rubber (PVC, maybe) ones have under-sized screw holes for a 100% seal as compared to a dried out original cork seal.
Old sending unit gaskets are notorious for leaking fumes which will rise up, flow out, and collect on top of the tank.
Carl
I just changed my tank and all the hoses and the sender and also have a fuel oder when full. I tracked it down to the screws holding the sender in. The gas sloshes and the gas push through the screws. A thin coat rtv on the gasket and the problem went away.
