5 members (J Lucas, Gray_Ghost, msmall, 2 invisible), 93 guests, and 2 robots.
Topics128,075
Posts1,055,918
Members48,429
#1191138 11/16/2016 8:46 PM
Crusing in the Passing Lane
Finally got the head off my 503. HRL was kind enough to add Sodium Silicate(water glass) to the water since combustion air leaked into the water, due to some true genius not tightening all the head bolts. We(HRL and I) got it home from Arkansas, OK.
Started leaking again, so decided to do a valve job and replace the head gasket. Tried to get the head off, wouldn't move, tried lifting, wouldn't move again, added shop air to 3 jugs, no joy, added shop air to all 6 jugs-that is 150 psi times 4 9/16" bore x 6 jugs, tried lifting more, finally tried lifting at various ends of head, got air leak so I knew I was making progress, finally got it off after careful lifting and relaxing many times over the course of a month or so.
Head and block look OK. Going to mill the head 60 or 90 thousanths, since the compression ratio is only 6.5 to one. The moral of the story, is be careful with the use of Sodium Silicate and how long you leave it in. I doubt the addition of antifreeze made the difference.
Ed
Hmmmm- - - - -good to know! That stuff hardens into a glass-like substance with a melting point up around 700+ degrees when exposed to combustion heat. Apparently it also makes a pretty good glue! I've heard of oldtimers loosening the head bolts a turn or so and driving around the block a few times with repeated full throttle applications to loosen up a stuck head. Flathead Ford V8's with studs instead of head bolts were notorious for getting the heads stuck tight, just due to rust bonding the studs and the head together, no water glass needed!
I thought of that, after I found how hard to get off, too late then.
Ed
cff Offline
Hey Ed. Ron here. Not trying to hijack this thread, but I thought since you're on here maybe you could help me.My truck is a 54 930 fire truck with the 503 too. I removed the pump assembly, but the pump was holding the disc brake/ parking brake assembly in place. What did the normal non-fire truck have to hold the parking brake assembly in place or what can I do? Thanks, Ron
The pump [censored]'y was already removed from my truck when I got it. There is a Tru-Stop disc brake on the back of the 5 speed. I cannot quite picture your "pump holding the brake assembly in place." I have replaced previous pumps with a 'Brownie' and found a True-stop that fits. It is always best to have the brake on the last transmission.
Ed
cff Offline
Thanks Ed.
I presume you have 'juice' brakes, can you just disassemble the pump and use the brake part only? Unless you want a brownie for road speed.
I don't know if the brake will fit on the back of the 5 speed, that is where mine is.
Ed
