1 members (Gray_Ghost), 65 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1191480 11/18/2016 11:14 PM
Hi all, I've come across a 59 Canadian Pontiac 261 that is currently set up for a by pass oil filter. I've read some articles that suggest if the dowel in the block is driven in the engine could become a full flow, another article doesn't
recommend this as it might damage the block??
Does any one have some experience with this and how did it work out?
good planning is no substitute for dumb luck
I had no trouble driving the dowel into the block. I sprayed it with Kroil a few times a day for about a week, then I used a punch just smaller than the dowel. It took a couple good whacks to get it moving. I was too timid at first. Once it started, it went in steadily.
It goes in 5/8". I bent a piece of wire to use as a depth gauge. You'll be able to tell when it bottoms out by the feel of the hammer. I tapped easier as I got close to the end.
Good luck,
Matt
