7 members (Cletus1950, TexasJim50, klhansen, Otto Skorzeny, Jon G, 2-Ton, 1 invisible),
80
Mod | | | Forums66 Topics128,281 Posts1,058,460 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | I have seen stainless steel micron mesh permanent oil filters that can be cleaned in a ultrasonic cleaner. It appears that most of these are for motorcycles, ATV's and snowmobiles. Does anyone make these filter cartridges for automobile applications, particularly cartridges that fit both the Fram and AC oil filter canisters?
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | The ones I've seen are flat screens sandwiched between aluminum plates with very small dimension filter screens. When an old style canister filter element is disassembled, there are many square feet of available surface area. I can't imagine the small mesh screens running very far without clogging and becoming worse than useless. Jerry
| | | | | Joined: Nov 2001 Posts: 1,523 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,523 | I have an old Frantz toilet paper filter set-up. Kinda hesitant to use it though,,,,,, especially with todays toilet paper. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I use tp in my air line filter. It gets wet but still works without disintegrating.
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Found a company that makes the reusable stainless steel micron mesh filters, but nothing to fit our canisters...Fram or AC. K&P Engineering is the company I found on the web. Any further ideas? Cost prohibitive?
Denny, if you read this... maybe we could design and make these?
Tim
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I'm with Jerry, although an interesting idea I think a stock paper filter element is the safer bet.
If they can fit the same area of metal mesh/screen filter material as the stock paper filter then it'll probably be difficult to fully clean. If they don't put as much material in then chances are it does not flow as much as stock paper filter, or can't hold as much dirt, and or it doesn't catch as small a particles as stock.
Grigg | | | | | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | My wife had a 2001?? Toyota that had a screen filter, That looked like a coffee filter, A plastic framing with screen windows, Looked like nylon screen very fine It fit in a screw caped hole cast in the front of the block, Unscrew cap pull out screen replace screen screw in cap you are done. No need to crawl under car and get oily.The car did use 5w-30w.easy pumping and probably still has a pressure relief. To do a chev canister, A screen tube covered ends with grommets to slide over central tube. would need to be as large a diameter [for flow] as possible and be stout enough to not collapse. HMMMMMMMM BUT if you really want to keep you're oil clean filter the intake of the oil pump. Thinking about stuff like this does not help my smoking habit AT ALL. | | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Anybody else remember the "filter" on the air cooled Volkswagen engines? It was a dome-shaped circular screen around the oil pump pickup tube at the bottom center of the crankcase with the drain plug in the center of the filter cover. It was about as worthless as an air freshener in an outhouse! Jerry
| | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | Some military vehicles from the early 50's used a "Cuno" filter which had various plates inside. The idea was to just turn the handle on the top and it would brake up the chunks and they would fall to the bottom. I think they were also used on aircraft. They could also fall into the "air freshener" category. Fred
| | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | Anybody else remember the "filter" on the air cooled Volkswagen engines? It was a dome-shaped circular screen around the oil pump pickup tube at the bottom center of the crankcase with the drain plug in the center of the filter cover. It was about as worthless as an air freshener in an outhouse! Jerry Hey now! That was a great filter. It kept all of the 1/8" square bits of piston skirt out of the oiling system in my '73 Bug. Well, for as long as I had any pistons left in the engine anyway...
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | My wife had a 2001?? Toyota that had a screen filter, That looked like a coffee filter, A plastic framing with screen windows, Looked like nylon screen very fine It fit in a screw caped hole cast in the front of the block, Unscrew cap pull out screen replace screen screw in cap you are done. No need to crawl under car and get oily.The car did use 5w-30w.easy pumping and probably still has a pressure relief. That is a regular filter cartridge, not really a screen filter. Replaced plenty of them over the years.
Bill Burmeister | | | | | Joined: Mar 2011 Posts: 107 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 107 | The 1937 American LaFrance V-12 I have has a Pur-o-lator reusable oil filter on it. It is essentially a stack of round brass shim stock in alternating layers in a pattern to produce a cylinder with some gaps a few thousandths tall and wide all over it. It filters out things like rocks, sticks and the small birds that carried in the rocks and sticks. I'm not sure its terribly effective at filtering out particles that could be damaging...On the bright side, once the oil leaves the filter on that engine it does pass through an oil to water cooler, so at least you have cool oil with small chunks circulating back into the engine.
From the outside it looks like a canister filter attached to the top side of the oil cooler. The brass element fits over a hollow tube and works similar the bypass filters commonly found on our GM engines, but with a larger hole to allow full flow. | | |
