4 members (1955 1 Series, baldeagle, Shaffer's1950, 1 invisible), 95 guests, and 1 robot.
Topics128,015
Posts1,055,335
Members48,419
#11906 11/03/2002 12:42 AM
Junior Member
Junior Member
The 235 on my 54 3800 wont start. I just finished painting the truck, but I left the engine intact, was planning to rebuild later. Anyway it really did run when I parked in. Now I cant seem to get it started.
Its cranking fine, just not starting. My first guess is that the carb is gummed up.
Any advise would be appreciated.
THanks
Crabby Dave
54 1ton
#11907 11/03/2002 12:58 AM
1.Are you getting fuel squirting in the throat of the carb when you pump the throttle?
2.Do you have fire at the points and or plugs?
#11908 11/03/2002 1:52 AM
check coil wire for contact or corrusion
Redryder pix
My Hotrod
