8 members (78buckshot, Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible),
38
10
Mod | | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11906 11/03/2002 12:42 AM | Joined: Aug 2001 Posts: 20 Junior Member | | Junior Member Joined: Aug 2001 Posts: 20 | The 235 on my 54 3800 wont start. I just finished painting the truck, but I left the engine intact, was planning to rebuild later. Anyway it really did run when I parked in. Now I cant seem to get it started.
Its cranking fine, just not starting. My first guess is that the carb is gummed up.
Any advise would be appreciated.
THanks Crabby Dave
54 1ton
#11907 11/03/2002 12:58 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | 1.Are you getting fuel squirting in the throat of the carb when you pump the throttle? 2.Do you have fire at the points and or plugs?
#11908 11/03/2002 1:52 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | check coil wire for contact or corrusion Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
