7 members (Gdads51, GrandpasJimmy, SmalltownTRKGuy, Jon G, Otto Skorzeny, Bill Trotter, Bill Hanlon),
108
Mod | | | Forums66 Topics128,194 Posts1,057,248 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 10 New Guy | | New Guy Joined: May 2005 Posts: 10 | Not being much of a body man I purchased 2 lower rear corner patch panels for my 57 3100 abd went ahead and cut out the exact size of the patch minus about one inch. I removed the old skin only to find an inner panel. This inner panel seems to be part of the floor pan. Is it? I have read where some kids just fab their own piece of inner panel if you're not building a show truck. I have not found inner patch panels anywhere or else I would just buy them and weld them in too. Anyone know? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes the inner is part of the whole inner cab stamping - doesn't usually require replacement, so you won't find any patch for it, but if there's parts in there rotted, they could be replaced from scratch .... or cut back to clean metal and left alone
Bill | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | If you look at Brotherstrucks.com under their tech articles, they have replaced the outer corner but deleted the inner. They added a brace and covered the hole inside. I am considering this, but not sure which way to go, new outer and inner or outer and delete the inner. both have a lot of welding. | | | | | Joined: Sep 2005 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 96 | i plan on deleting my inner cab corner but if you want one you can find them here:www.ricos-rods-and-relics.com i've never ordered from them but it think the guy who owns it is on this forum. | | | | | Joined: Sep 2005 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 96 | to find it you need to go to part locator click pickup then scroll to your year and it should be on page ten. hope this makes sense | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I did replace mine on my 57 Chev. I would recommend replacing it instead of a workaround because it keeps everything lined-up as intended (I replaced pretty much all of the lower cab). I found mine at LMC. | | |
