3 members (Danielbolt, bluechev, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | I have a '57 Chevrolet 150 with a 235 and factory overdrive. It has a vibration just off of idle that I can't seem to pinpoint. It's fine at idle but just off of idle (my carb throttle shaft is warn and sometimes it idles a little fast until I punch the throttle) and at this faster idle it has a very noticeable vibration. Also, when I wind the car up in 3rd gear to get into overdrive the vibration is very present until I get into overdrive.
My suspicions are: Harmonic Balancer/crank/flywheel. Perhaps even an ignition miss, but I don't think a miss would cause the vibration I'm getting. I forgot to add that the crank and balancer has been drilled so that the balancer can be bolted on due to the keyway being worn.
What should I do to begin diagnosing this issue?
Thanks, Brandon
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Brandon,
I won't be much help, but I'd check the simple stuff first.
Have you checked the tightness of the motor mounts? Have you checked all bolts between engine, transmission and rear end? Are u-joints good?
Good luck,
| | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | "I forgot to add that the crank and balancer has been drilled so that the balancer can be bolted on due to the keyway being worn."
Is the worn keyway on the balancer, or the crank, or both? I would start looking there. All the bolt will do is keep the crank from falling off once the balancer has been installed with an installer tool. It may hold it on straight, or anything but straight if the balancer and/or crank snout is goobered up. Carl
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | when did this problem start? any work done to this car prior to the vibration? could it be in the drive shaft or a motor mount. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Mar 2013 Posts: 186 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 186 | Start with checking plug wires, make sure the carb is adjusted right.points and condenser can cause problems.compression test can tell you a lot as well.always eliminate the basics first. Any of the above will cause issues when engine is under load. | | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | Thanks for the suggestions. I'll check on these and go from there. | | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | I can't remember exactly when this started, because the car had been put up for about 3 years. I don't remember this being an issue when I put it up, but I cannot say for certain.
I did install a new clutch and had the flywheel turned prior to getting the car ready for the road again. The previous clutch had been soaked by a rear main leak and would shudder when it got up to operating temp. Turning the flywheel and new clutch fixed that problem. Could this have anything to do with it? The flywheel will only install one way. | | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | A stupid question which I hesitate to ask. Did you fix the leaky rear main seal?
| | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Will it get rough off idle while in neutral? Or just when driving.? | | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | Both. Because the shaft is warn on the carb it sometimes sticks at redlights and idles a bit higher than actual idle. It has the vibration pretty bad at this time. I can punch the throttle and it causes the car to idle normally, and the vibration isn't bad. When I build rpm and I'm about to change gears, it's pretty bad and if I'm in 3rd gear on the highway it's can be bad until I shift into overdrive. In overdrive on the highway, it's not bad at all. | | |
