7 members (51sub, 41 chev, WICruiser, Oldpickupman, Gdads51, Charles in CA, 1 invisible),
92
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Well, the schedules have changed around again. The 49 COE that I had talked about as a future project, arrived today. The tractor project was put on hold. The client removed the grain body before shipping it down. I was able to identify the engine as a 283 with the stock 4 speed w/PTO. The big supprise was that the frame rails are twisted. The rear 5 feet of the frame look like a toy truck that someone stepped on. The truck had been so over loaded that rivets holding the rear cross member to the lower frame flange had sheared. With the springs mounted to the outside of the frame, the force twisted the bottom of the frame rails out. The spring mounts are no longer horizontal , but angle upwards. In typical barnyard repair, instead of trying too straighten the rails, they just welded the ends of the cross member to the rails where they were so they wouldn't bend any more. Just more work! | | | | | Joined: Feb 2011 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 27 | Post some pix, as I have a 39 COE that I have not started on yet, as you said it is a future project. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | On further examination, the frame is worse than I originally estimated. It's not going to be practical to straighten it. On to plan B. There are a couple pics here, but I will start a new album for this project when it gets going. http://s1276.photobucket.com/user/jsdesign2/library/ | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Moving ahead with the project, looks like we have another frame coming (long story, fill in details when I actually see it). WHEELS, need all new ones. Truck has a mixture of 3 piece and 1 piece rims, 2 missing, some junk with ovaled out holes. Because of the poor selection of 20" radial tires, client wants to change wheel size. Looking for 22.5" (7.5?) so that 70/75 series tires will give me 36/37" diameter (original 8.25 were 38.5-39"). Know that nobody made rim that size with 4.75" center. Not a problem, can machine spacers. Anyone know of a current source of New wheels, rather than searching junk yards?
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | As I go through the evaluation of the truck and make the parts needed list, I will post to the Wanted forum. However since the COE is a Big Bolt only, and a small sub set at that, I will also mention them here as some of us don't visit there often. Since the PO removed the seat and tack welded a bucket to the seat riser, I need seat bottom and back. Also the "floor hump" panel. Thanks for the help in advance. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Finally got some pictures onto Photobucket (between the ads!) Both trucks stripped down to the chassis. late '49 cab will go on the repowered '51 chassis. moving forward. http://s1276.photobucket.com/user/jsdesign2/library/51%20ceo
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Gentleman in AZ had some made up with modern rims, $200. or $300. As I recall.
Ed
| | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | I think that may be Kent Zimmerman. (LightHolder's Dad) | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Blue Chevy COE, in ATHS magazine, Prescott, AZ.
Ed
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Thanks guys. Sorry, I tacked the pics onto the original thread. Worked with the guys at Wheels Now, designed a custom rim that looks like the original in 22.5 and will take a 9.00-22.5, has a 38" diameter just like the old 8.25-20 Have been posting on other CEO threads on other issues with the truck. | | | | | Joined: Jul 2004 Posts: 2,998 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,998 | Looks like the one used to belong to a John Deere dealer! | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Worse! It has a couple big "Hot Wheels" decals on it. That's the one that had the 283 V-8 in it.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Are the Wheels Now wheels Fe or Al?
Ed
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | welded steel. The hope is that no one will know they aren't original without reading the tires. | | |
