5 members (TooMany2count, Southerntruck, Gray_Ghost, Ridgeback, GMCJammer51), 111 guests, and 2 robots.
Topics128,050
Posts1,055,751
#1189471 11/04/2016 5:17 PM
A friend called me yesterday to tell me about his new acquisition of a 55 first series Napco truck. It is a 3600.
I don't recall ever seeing one but that doesn't mean they don't exist. The former owner claims it was previously a Forest Service vehicle and it came from the local mountains.
His question was about the shift levers for the transfer case. It has 2 levers which I presume from owning several Willys vehicles are for in/out and H/N/L. He says it has a Napco data plate but no shift pattern data plate.
Any information or opinions are welcomed.
Fred
rfs56trk #1189484 11/04/2016 6:19 PM
An after-market NAPCO conversion was available as a non-factory/non-dealer-installed option/conversion. It is shown in contemporary GM Truck (special equipment) Blue Books.
Maybe someone knows if any documentation is online?
You could try looking/searching in the Gallery to try to find a member with a NAPCO conversion?
rfs56trk #1190128 11/08/2016 1:10 PM
You assumption for the twin transfer case levers is correct. Much like old 2 speed cases found in applications from the beginning of time to the late 1960's.
Sounds like a neat vehicle, I hope you friend treats it with care.
BTW, there is a website dedicated solely to NAPCO trucks.
Lots more pictures
rfs56trk #1190133 11/08/2016 1:31 PM
Great truck. The url for the NAPCO site is: http://www.napco4x4.org/
I'm not sure, but the second lever may be for the Power Take Off (PTO) unit.
don
rfs56trk #1190154 11/08/2016 5:16 PM
Thanks for the input. Hopefully I'll get an opportunity to check it out as soon as he is able to bring it down from the mountains.
I has been sitting for some time and has a huge camper on it so he is trying to work out the logistics of getting it moved.
From the picture he sent me it appears to be in relatively good condition. I'm sure it needs all the usual maintenance items like carburetor, fuel tank, radiator, battery, brakes, etc.
Fred
rfs56trk #1190298 11/09/2016 1:27 PM
I have seen a few of these Forest Service Trucks around (the internet). Try researching them, you may find some specific info.
don
rfs56trk #1192349 11/25/2016 3:30 AM
I think this is the one you want:
http://www.classictruck.com/product...attern_plate_NA118/1947-55_Trucks_Decals
No middle lever if you don't have a PTO or if it's cable operated.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
