5 members (Bill Hanlon, 52Carl, Otto Skorzeny, SmalltownTRKGuy, 1 invisible), 80 guests, and 3 robots.
Topics128,094
Posts1,056,058
Members48,433
after putting a new rear main seal in we are yet to find a toque rating/specification for the crankshaft caps. is there a certain amount of torque needed or do you just use a little muscle to get them nice and snug?
No muscle unless applied to a torque wrench.
Try GM Heritage and the Old car manual project. Two great websites.
Where in the empire state are you? Jeffrey
queens, they were on tight enough where we had to use a breaker bar to get them to break lose but we don't know the torque rating is there one
What year and type engine are you working with? There is a spec, but it is different depending on what engine you're working with.
Bill Burmeister
1954 3100 235
100-110 ft/lbs
Bill Burmeister
As Bill posted, Adjust Main Bearing, Step 3.
To other members: if modern precision bearings are used in a 1954 235/261 block, is plastigauge measurement/adjustment necessary?
That procedure is still shown in the 1955-2nd series Truck Shop Manual. However, the 1956 Truck Shop Manual states that shim adjustment is no longer necessary (due to the introduction of precision bearings?).
A plastigauge check is always advisable with a used engine. You never know which of the many possible things a PO has screwed up.
I usually put one strip each of red and green on the mains, assembled dry, and torque them all down. Then remove them, confirm the spacing is correct,lube everything up with STP and do the final torque.
I have found a few supprises over the years.
