7 members (walter74, KEVINSKI, Hotrod Lincoln, Otto Skorzeny, Shade Baby, msmall, 1 invisible),
92
Mod | | | Forums66 Topics128,269 Posts1,058,401 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 15 New Guy | | New Guy Joined: Oct 2016 Posts: 15 | Has anybody tried finishing a frame at separate times?
I Have a smaller garage and am toying with the idea of finishing the rear half of the frame and then taking the cab apart and finishing the front end. Is there any issues with doing this?
Kregus Lakewood, CO
1946 2 Ton (I think)
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Not if you use proper preparation and use a good Epoxy primer like SPI or ppg. You can even roll or brush the SPI on. 3 coats and your done. Won't chip, fade, or fail and no need to use an undercoat over it...
| | | | | Joined: May 2007 Posts: 1,721 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,721 | I sort of attacked things this way a few years ago working over the winters and driving over the summers. Looking back I would not do again. It isn't the finish lines that were bothersome, it was the completeness of the projects. Once you have bed off you will want to do things like suspension and the brakes and you might not be able to get at all the lines and fittings up front. Once you start where do you stop. I would say I could be done in the short term. But looking long term I experienced some regrets. | | | | | Joined: Oct 2016 Posts: 15 New Guy | | New Guy Joined: Oct 2016 Posts: 15 | Thank You for the feedback
Kregus Lakewood, CO
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Good advice Hambone. When I started I heard the same thing but had no compressor or space or Experience in these areas.
Years later I do. Now I try to help those in similar straits (Dire). It was helpful to know what was preferred even if I wasn't there yet though.
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | That's what I started out to do , just the bed and frame under it....crap | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | wait until you try and find your way out at the "It's Finished" end!
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | wait until you try and find your way out at the "It's Finished" end! boy are you right !!!! | | | | | Joined: May 2007 Posts: 1,721 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,721 | Reminds me of a situation right in Stovebolt HQ as Milliman and I were looking at a 1/3 decomposed 62 C10, when John, the gracious one, suggested, "just 4 bolts and that cab comes off and you can do the whole thing." While his advise was technically correct, logistically it was not consistent with my level-of-effort assumptions. Of course time and money calculations also needed adjustment. 1 six pack and 4 bolts later, I was in over my head. All said and done, the experience, learning, friendships and camaraderie gained along the way are precisely why we are here. Whichever approach you take, don't rush, call for help when needed and enjoy the experience.
| | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | Whichever approach you take, don't rush, call for help when needed and enjoy the experience. That's the best advice right there!! | | |
