| | | Forums66 Topics128,088 Posts1,056,390 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 122 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 122 | What are the safe lift points to use when raising an AD truck with a 2-post lift? Anywhere on the frame? Anyplace to avoid (beside the obvious: fuel lines, brake lines, etc.)? Thanks! | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | You pretty much got it. Any place rear of the front spring and front of the rear spring. No problem on pickups. Long wheelbase trucks (1 ton and up) pay attention to the balance point of the lift. | | | | | Joined: Oct 2013 Posts: 122 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 122 | | | |
