| | | Forums66 Topics128,022 Posts1,055,384 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 31 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 31 | Got a '57 235 was in a 48 2 ton.Finally got it to start. No oil pressure. Spun the oil pump with a drill. Oil runs out the back somewhere. Engine is out, got a newer oil pan which I am looking to get restored somewhere. Farm it out for lack of tools, patience, and ability. Is the rear oil seal that hard to replace? What else would cause that? | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Check the "freeze" plug at the back of the camshaft bore. If it has come loose for some reason the oil pressure will vent into the bellhousing. A bad rear main bearing seal WILL NOT affect the oil pressure. It will just cause a puddle. Jerry
| | | | | Joined: Oct 2007 Posts: 31 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 31 | Thanks! I'll check that in the morning. With the engine out it's easier to check | | | | | Joined: Nov 2012 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 39 | The oil pressure gauge line connects at the back corner on the side of the block. Make sure the line is not broken or missing.
Chad | | |
