5 members (Brian Moore, moparguy, ShopRag, klhansen, TooMany2count), 75 guests, and 3 robots.
Topics128,047
Posts1,055,533
Members48,424
#1188276 10/26/2016 4:00 AM
New owner looking to read the info off the vin plate, have seen some have listed build factories and delivery dealers. Can i get some help with that. I now my 46 was bought in 48 and lived on the same ranch since.
racerBob #1188315 10/26/2016 3:31 PM
Post the info here and someone will likely decipher it.
racerBob #1188357 10/26/2016 7:20 PM
Well, I know the family bought the truck in 1948, it is a Master 1.5 ton with flatbed dump. The plate is very worn so other that the vin being 21os111743. If there are certain things in certain places on the truck to check I will.
racerBob
racerBob #1188662 10/29/2016 3:11 AM
Guess I should have mentioned it's a Chevy.
racerBob #1188668 10/29/2016 4:36 AM
The number on the cab will not be found in any other place on the truck. I'm surprised someone with a book hasn't deciphered what you posted.
Sometimes info can be gleaned from an engine serial number also. I don't know if that was the case with '46 numbers or not. Of course a bunch of engines have been changed over the years.
racerBob #1188672 10/29/2016 5:17 AM
Serial # : 21OS111743
Mfg Year : 1946 (interim)
Model : 1.5 ton
Wheelbase : 160 inches
Plant : Janesville, WI
Source> Stovebolt Page -- the VIN Buster
Check 1946 Chevrolet Truck Serial Numbers
Source> Restoration Packs & Specifications Data
racerBob #1188726 10/29/2016 7:00 PM
Wow, thanks for the vin buster lead. results are Mfg 1946 (interim), 1.5 ton, Wheelbase 160 inch, and mfg plant was Janesville WI.
But I see that is what was in the post now,
Also thanks for the other source info, Learning a lot about my bolt.
Now back to working on the brakes.
jorb #1188731 10/29/2016 7:16 PM
21OS111743, the number 1 after the letter S is the Letter I = eye.
21OS-I-11743
21 - Assemply Plant , Janesville, WI
OS - 1946 Model Year
OS - (interim) = 1st series Design, (PK is the 2nd series Design)
OS - 4400 Series Model
OS - 160 inches Wheelbase
OS - 1.5 = 1 1/2 ton
I - September, Month truck was Assembled
A = Jan.
B = Feb.
C = Mar.
D = April
E = May
F = June
G = July
H = Aug
I = Sept. Your truck
J = Oct.
K = Nov.
L = Dec.
11743 - Number of that model of truck Assembled at the Janesville, WI plant, Starting at 1001.
Your truck was the 10,742nd truck to roll off the assembly line.
Source> 1946 TRUCK MODEL SERIAL IDENTIFICATION
racerBob #1188763 10/30/2016 12:56 AM
Jorb,
Not trying to be to picky, but his truck would be the 10,743rd unit as the first truck was 1001, so you only subtract 1,000 from his number.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
racerBob #1188819 10/30/2016 4:27 PM
The LMC catalog has some good information about the VIN in the front of the catalog. Easy to decipher. Hope it helps.
Tramp
dj durant
More pix on Flickr
racerBob #1188920 10/31/2016 1:27 PM
Thanks jorb, that is a fantastic tidbit of info, useful.
jorb #1189222 11/02/2016 1:40 PM
Well though the plate is very faded, the digit definitely stamped with the #1, were there reasons?
racerBob #1189261 11/02/2016 7:30 PM
The "1" and "I" stamps/dies were often mistakenly interchanged (as were "O" and "0").
