0 members (), 62 guests, and 7 robots.
Topics128,021
Posts1,055,355
Members48,420
#1186086 10/09/2016 4:43 PM
my angle strips do not line up with cross sill holes 52 chevy
Sorry for what might sound like a silly question but did you try and flip them around? Maybe the side rail is made for the other side? I found on my flatbed the strips had to go a certain way.
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
i did and they r the same way
Some more info might help.
Did they come off the truck?
If not do they match the originals?
If new, who did you buy them from and what do they have to say on the matter?
Insomniac
Insomniac
The angle strips go over the cross sill. These photos (very good and often linked here) may help.
Bed Photos
Gord 🇨🇦
1954 1/2 ton 235 4 speed
got them from classic parts that got them from mar-k. guy says they don't have to line up they go over wood. i understand that but some holes land on cross sills and not lined up with them holes. i see brads pics but can't really see the front bed pannel, how the angle goes in. i know there is a slit on the front pannel groove and angle fits in there but holes do not line up
sorry grigg they r new
also why does the angle strip hit one fender bolt on each side?
Could your cross sills be mixed up or reversed . Mine is a 54 the box is slightly different.the angle pieces I don't think should run by the fender bolt. If it does then it would have been like that on the old angle strip.maybe strip has to go up or down from the bolt.just looked at the picture looks like the rear of the fender has one bolt that goes through the strip in the picture the hole is there with no bolt in it yet.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
See if these pictures help.
http://www.gregwapling.com/hotrod/chev-trucks-47-55/install-bed.html
Somewhere a day or three ago I saw the link to a whole (I thought google album) with better resolution pictures but I just can't find it...
1952 Chevrolet 3800 pickup
---All pictures---
Insomniac
Insomniac
Same photos in my post upthread....
Gord 🇨🇦
Thanks, if it were a snake...
got it thanks
In your photo, it looks like you are lining up the ends of the bed strips with the ends of the angle strips. The angle should be offset to the rear about 7/8" or so. It sits on top of the rear sill at the back and does not reach the front panel so not to interfere with the front panel bolt flange. That should make the cross sills line up with their corresponding holes in the angle. The angle does not just bolt to wood only. It is a critical structural member of the bed assembly and needs to be bolted to the cross sills and rear sill.
Mar-Ktech
what is wrong with this picture. the angle strips hit 2 bolts on fender bed <a href="http://s1296.photobucket.com/user/cuz2424/media/IMAG0535_zpsm1etg0cq.jpg.html" target="_blank"><img src="http://i1296.photobucket.com/albums/ag3/cuz2424/IMAG0535_zpsm1etg0cq.jpg" border="0" alt=" photo IMAG0535_zpsm1etg0cq.jpg"/></a>
Do you have the bed blocks in?
Dennis
40 Chevy 1/2 ton
yes
nothing is bolted yet
Insomniac
Insomniac
I think those lower fender bolts are supposed to go through the angle strips. See Brad Allen's pictures I linked to upthread.
Gord 🇨🇦
i did but i dont see any holes in strips for them
Insomniac
Insomniac
You can't see the holes in the pictures? (I can see them) Or do you mean that there are no holes in the strips? (In which case, you will have to drill them yourself)
Gord 🇨🇦
ok i can do that. i just thought when i bought them everything would line up.
Might verify you got the correct kit? Or like Gord&Fran said you may have to drill them to fit your bed.
Insomniac
Insomniac
Something else to look at - check out step 12,
Bed Instructions
Gord 🇨🇦
And Step 13
ok got it thanks guys i will post pics when i'm done
be done hopefully tomorrow. alot of nuts and bolts
Looking good!
thank u
Moderated by  Dusty53
