3 members (Gdads51, TUTS 59, 1 invisible), 119 guests, and 8 robots.
Topics128,088
Posts1,056,124
Members48,435
#1188889 10/31/2016 2:39 AM
I have some wonderful dents in cross member 6 on my 46' 1 1/2 ton. Do any of you have some good advice for getting them out?
For member #5 I used plate steel and c clamps and it worked really well but #6 is a thicker metal and that method isn't working this time.
Kregus
Lakewood, CO
1946 2 Ton (I think)
Red dot, center of chest ...
Have you tried heat? Plate steel plus C clamps plus heat might do the trick.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Use some heat and an air-powered hammer. It's noisy, but it works. These old frames can be heated and worked hot without much danger of losing strength, not like the alloy frames on newer vehicles.
That was my concern with using the heat, I was worried about ruining the frame
Kregus
Lakewood, CO
I grew up around a shop in the 1950's where we heat-straightened frames all the time. The low carbon steel used before the 1980's or so doesn't lose much if any strength when heated to a dull red color. Just don't approach the melting point and you'll be OK.
Thank You everybody
Kregus
Lakewood, CO
